HELP Solve for R and I
Discussion in 'General Electronics Chat' started by tjjam2003, Apr 5, 2006.
  1. tjjam2003
    Apr 5, 2006
    22
    In a Series-Parallel circuit, how do you find the resistance and the current if only the voltage is given? 5 resistors in series and 1 resistor in parallel.
    R1= 3 ohm Voltage= 3V Current 1A
    R2= 5 ohm Voltage =1.65 current 0.33A
    R3= ??? voltage= 4 volts (parallel)
    R4= 4 ohm Voltage 1.32 Current 0.33
    R5= 1 ohm voltage 1 volt current 1A
    R6=3ohm voltage 0.99 current 0.33
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Your problem would be clearer and easier to solve if you could provide a sketch of the circuit.
    hgmjr
  3. david mendes
    Mar 23, 2006
    6
    Your values seem uncoherent... the only possibility to underestand the problem is by designing the circuit...
    Dd.
  4. JoeJester
    Apr 26, 2005
    3,394
    1,212
    With your detail, I don't see your initial standard ... 5 resistors in series and 1 in parallel.
    I can see three branches in parallel, one single resistor, on with two in series, and one with three in series.
    If there is an associated drawing, post it.
  5. windoze killa
    Feb 23, 2006
    605
    24
    I also responded to this somewhere else. Your values do not make sense.
  6. n9xv
    Jan 18, 2005
    329
    Draw it. Use paint/Paintbrush, zip it, post it.
  7. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    You don't.
    <!--QuoteBegin-tjjam2003
    @Apr 5 2006, 08:13 AM
    [post=15853]Quoted post[/post]​
    [/quote]
    Okay... R1 and R5 are in series with each other, yes? 1A each and 4v across the two of them.
    R2, R4, and R6 are in series as well... 1/3 amp each and about 4V across the three of them.
    If R3 is also in parallel, then there is no way to know current or resistance, save that R>0.
    If the above is wrong, then the numbers given are also wrong.
  8. Mazaag
    Oct 23, 2004
    255
    :D √ Draw It , Paint It , View It, Change It, Print It, Zip It , Post - Upload It √ :D
