Help! Simple DC circuits to analyze for university project?
Discussion in 'The Projects Forum' started by Nuno Fernandes, Feb 24, 2016.
  1. Nuno Fernandes
    Feb 24, 2016
    9
    Hello Comunity!
    I have to make a project for one of my classes that consists in creating a DC circuit with mainly resistors and power sources. However, "real-life situations and innovative circuits are extra valued". It doesn't need to be complex, just some power sources and resistors. The point is to come up with the circuit and formulate a problema around it, and also solving it, so that I can present the problem and the solution to the class. Can someone give me some ideas based on this information? Thank you for your time.
  2. Dodgydave
    Jun 22, 2012
    5,143
    768
  3. Nuno Fernandes
    Feb 24, 2016
    9
    I was thinking of something like an exercise with a simple circuit with resistors and power sources where you have to calculate tensions, currents, resistences and power ratings. Basically what we need to do is to formulate a problem, as if we were the teachers, and then solve our own problem. Some of my colleagues have circuits with LED's, for exemple, simplifying it to connecting power sources and resistances in series and making the problem about what tension should the power source have so that the maximum of current flows through the resistance. Another colleague of mine has a problem with heaters, basically putting some resistances together and asking the total power rating of the system, among other things. Can anyone give me some ideas?
  4. dl324
    Distinguished Member
    Mar 30, 2015
    3,377
    651
    If your project is to come up a circuit and analyze it; having someone do it for you defeats the purpose of your assignment.
    If you will receive a grade for this work, it should be posted in Homework Help instead of Projects.
  5. Nuno Fernandes
    Feb 24, 2016
    9
    Hello! I didn't mean i wanted anyone to analyse it for me. English is not my first language and i'm sorry if I made it sound like that. I just wanted some help coming up with a circuit so that i can analyse it
  6. DickCappels
    Aug 21, 2008
    2,766
    667
    Consider electrical distribution for a lighting system.
  7. dl324
    Mar 30, 2015
    3,377
    651
    I took the following statement to mean that the actual problem was worth extra credit if it was considered innovative.
    What year are you in your studies?
  8. Nuno Fernandes
    Feb 24, 2016
    9
    1st
