Help! simple circuits problem but im a newbie
Discussion in 'Homework Help' started by bvisonl, Oct 30, 2010.
  1. bvisonl
    Oct 30, 2010
    Hi, i have this Homework and its just 1 problem (out of 15) that i cannot do. if someone could help me i would really appreciate it!!:
    I have to find both C and R values so that the max transfer of power goes to R and also whats the value of that power.
    Thanks in advance .
    Regards,
    Benjamin
  2. eblc1388
    Nov 28, 2008
    1,542
    102
    I hope the following will help.
  3. bvisonl
    Oct 30, 2010
    i didn't tried that so thanks for that, but what i don't really know its how to get the C and the R value out of the Thevenin its a bit confusing.. and my teacher never explained that :mad::mad::mad:
  4. Kermit2
    Feb 5, 2010
    3,851
    966
    Try assuming the resistor values are identical and see if you can put Z(inductor) = Z(capacitor) without using some ridiculous value for C.
  5. thatoneguy
    Feb 19, 2009
    6,357
    718
    Convert raidans/second to Hz.
    Maximum power transfer occurs when impedance is matched.
  6. bvisonl
    Oct 30, 2010
    I got it already, i just had to find the Zeq, to find the R for the MTP and it was the parallel of the R and XC not just (R - JX) right away, so from the start i got it wrong by adding the impedance and the resistor like if they were in series, therefore, everything after that would be wrong, including the thevenin.
