Help resetting powered HDMI Splitter 1x2
Discussion in 'General Electronics Chat' started by doby, Nov 27, 2015.
  1. doby
    Thread Starter Active Member
    Aug 17, 2011
    43
    An HDMI splitter I have has stopped working. All the indicator LED's on the unit work as they should but there is no output.
    Opening up the casing and inspecting the PCB reveals 4 contacts labelled 'VCC', 'REST', 'SWIW' and one that's unlabelled which I've confirmed is ground. Googling pictures of similar PCB's shows ones that have pins soldered in place so they can be jumped.
    So my question is probably a simple one; which 2 of the pins must I short to reset the unit, 'REST' and ?....VCC or GND
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    I think the REST system must be grounded to reset the system:
    Bertus
  3. doby
    Aug 17, 2011
    43
    Ok thanks, I'll give it a go
  4. spinnaker
    Oct 29, 2009
    5,074
    1,176
    Chances are it is fried if you shutdown the power and turned off all attached devices and it still does not work.
  5. doby
    Aug 17, 2011
    43
    Yeh this does seem likely. I think it suffered a power surge when I plugged it in and since then it hasn't worked. After reseting it I now get geen lines across the whole display but I could make out a picture briefly while shutting down my PS4 so its not totally dead. Probably not worth spending any more time on it though.
  6. spinnaker
    Oct 29, 2009
    5,074
    1,176
    Same thing happened to me.
