help required
Discussion in 'The Projects Forum' started by ashumudus, May 3, 2011.
  1. ashumudus
    May 3, 2011
    i have to develop a circuit similar to binary serach
    here is the statement
    FunBrain Magician
    The FunBrain Magician is game that will pick a secret number between 0 - 31. User guesses what number it is. If the guess is high or low, FunBrain will give a hint.
    User will ask the magician to generate the random number by setting input GRN = 1. Magician will take the guess after every 4 cycles. If the answer is correct CA will be set to 1, otherwise H or L will be set accordingly. In the end magician should tell in how many turns user is able to guess the correct number.
    Input
    Clock Pulse CP
    Generate Random number GRN
    Guessed Number C0…C4
    Output
    Correct Answer CA
    Number of guesses D0…D4
    High H
    Low L
    i need some serious help
    can some one guide me ill be very gratefull
  2. marshallf3
    Jul 26, 2010
    2,358
    201
