Can you give us the part number of the SSR?
What is the load current through the SSR?
The reason for the ssr is for safety the soilnoid being operated is 220vac.Your load (3.5va = 16mA) is pretty small. Why do you want to use a SSR?
Do you require the optical isolation for safety? Maybe the zero-cross capability?
Anyway, the control input already looks TTL compatible. They do not specify the input current at 5V, so it may be prudent to buffer the input with a 7407 open-collector buffer with a pull-up resistor.
Input Data Operating Voltage 3~32VDC Min. ON / OFF Voltage ON > 2.4V , OFF < 1.0V Trigger Current 7.5mA / 12V Control Method Zero Cross Trigger
by Aaron Carman
by Duane Benson
by Duane Benson
