help required switching a LV circuit from a HV source
Discussion in 'General Electronics Chat' started by skydemon, Jan 1, 2007.
  1. skydemon
    Jan 1, 2007
    Hi all, I need to build a circuit that will switch a low voltage signal when a high voltage (240VAC RMS) is detected. Basically I have an existing circuit as below:
    AC LOAD
    where the '/' is a switch on the active line. (sorry for the crappy drawing :). Once that switch is closed I need to close a circuit between an input and a 5V rail but I am unsure how to accomplish this. The best way I can think of doing it is to wire in a step down transformer/rectifier/filter to drive a relay but this seems overly complicated for the outcome I need to achieve. The other way is to use the 240V switch to connect the 5V rail to the input but I will need someway to isolate the high voltage portion of the circuit.
    Can anyone suggest the best way to do this?
    Cheers
    Mick
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    How about a relay with a 240 volt coil?
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Why would rectifier and filter be needed to drive a relay? A small transformer should be all that's needed for driving a relay.
  4. skydemon
    Jan 1, 2007
    hmm...yeah in hindsight that was stupid, of course a relay coil could be driving off AC..silly me, however I had a bit of a look around and could not find a relay with a 240V coil. Every 240v relay I found was rated to 240v on the contacts but not the coil...
  5. wireaddict
    Nov 1, 2006
    133
    Howdy, welcome aboard! Potter-Brumfield/Tyco make small relays with 240 VAC coils with up to four "C form" contacts and NTE probably does, too. Check with Google.
  6. skydemon
    Jan 1, 2007
    cool thanks! ill check it out :)
  7. KrisKizlyk
    Jan 6, 2007
    8
