Hi all : )
I'm trying to build a circuit that will generate a pulse and need ur guidance in it
Refer the attached file for details of pulse.
Period of Pulse = 400 msec
Duty Cycle = 50%
With Two distinct voltage levels of 6 and 8 V.
first im trying to design the circuit on paper and need ur guidance in it to make sure im on right track
i plan to use 555 timer ic in astable mode and generate a pulse of 8V, period=400 msec with 50% duty cycle
but the low voltage level in this case is going to be 0 V. and not 6 V which is required.
so after timer ic i plan to connect a clipping circuit using diode which will clip the low voltage level to 6 V.
will this circuit work ??
is there any better idea(circuit) to generate the required pulse
Duty Cycle = 50%
