Help required for sineusoidal PWM
Discussion in 'Embedded Systems and Microcontrollers' started by praveen_palaparthi, Sep 30, 2009.
  1. praveen_palaparthi
    Sep 30, 2009
    Respected sir,
    i AM PRAVEEN WORKING ON SINE WAVE UPS USING PIC MICRO CONTROLLER.I am having a problem and not able to solve i need ur to solve.Problem is i have written code for sinusoidal PWM of off line ups,i am getting sine wave at no-load when i put load the shape of sine wave changing to square wave i dont know what happening.At no load it is pure sine wave of harmonics 4% but with load as waveform is changing harmonics are increasing at full load harmonics are 27%.Full load is 160 watts as i have designed for 200VA UPS.
    Here i am posting the code and wave forms please help me where in the code it is making square wave.
    #include <pic.h>
    #define kp 57
    #define ki 32
    int out_voltage=0,out_voltage_1=0,tim_per=0x80;
    int ref_voltage=0; // ref volatge based on feedback
    signed int x=0;
    int xold=0;
    long y=0;
    long yold=0;
    int duty_cycle=0;
    long z=0,z1=0,proportional=0,integral=0;
    unsigned char sine_table_count=0,count=0,adc_flag=1; // Index into the sinewave reference table
    unsigned char Half_cycle_count=0,i=0; // Determines the halfcycle
    unsigned int sine_value=0x00; // Sine table value
    unsigned int d1;
    bank1 unsigned int const sine_table[32]={39,77,114,151,186,219,250,279,305,328,347,364,377,386,392,394,392,386,
    377,364,347,328,305,279,250,219,186,151,114,77,39,15};
    void main(void)
    /* setup stuff */
    TRISA= 0x2F; // PORTA pins as input pins
    TRISC = 0x00; // PORT C pins as output pins
    PORTC=0x00;
    TRISB=0xF2;
    PORTB=0;
    RB3=1;
    ADIF=0; // clearing A/D interrupt flag
    ADIE=1; // Enable A/D interrupt
    ADCON0 = 0x91; //A/D setup. set pin7 (AN4) as Analog input for volatge feedbak
    ADCON1 = 0xC0;
    TMR0=62; //0x3D; //0x3D;//0x5B; // TMR0 setup
    PSA=0;
    PS2=0;
    PS1=0; //0;
    PS0=1; //1;
    T0CS = 0; // Timer increments on instruction clock
    T0IE = 1; // Enable interrupt on TMR0 overflow
    PEIE=1;
    GIE=1; // Global interrupt enable
    GODONE = 1;
    while(1) // Loop forever
    static void interrupt isr(void) // Here be interrupt function - the name is unimportant.
    if(ADIF)
    ADIF=0;
    out_voltage=0;
    out_voltage = ADRESH<<8;
    out_voltage=out_voltage+ADRESL;
    ADCON0 = 0x91;
    ADCON1 = 0xC0;
    GODONE =1;
    if(out_voltage==0)
    out_voltage=500;
    if(T0IF) // Clear interrupt flag, ready for next
    T0IF = 0;
    T0CS = 0; // set up timer0
    TMR0=62; //0x3D; //0x5B;
    PSA=0;
    PS2=0;
    PS1=0;
    PS0=1;
    ref_voltage= sine_table[sine_table_count];
    if (Half_cycle_count)
    ref_voltage=-ref_voltage;
    sine_table_count++;
    if(sine_table_count==32)
    sine_table_count=0x00;
    if(Half_cycle_count)
    Half_cycle_count=0;
    else
    Half_cycle_count=1;
    x =ref_voltage-out_voltage_1;
    proportional=(kp*x)>>10;
    integral+=ki*x;
    y= (integral + proportional)>>6;
    if(y>=0)
    duty_cycle=y;
    if(duty_cycle>1023)
    duty_cycle=1023;
    if(y<0)
    duty_cycle=-y;
    if(duty_cycle>1023)
    duty_cycle=1023;
    if(Half_cycle_count) // positive half cycle
    CCPR2L = duty_cycle>>2;
    CCP2CON = ((duty_cycle&&0x03)<<4)+0x0C;
    CCP1CON = 0x00;
    else // Negative half cycle
    CCPR1L =duty_cycle>>2;
    CCP1CON = ((duty_cycle&&0x03)<<4)+0x0C;
    CCP2CON = 0x00;
  2. RolfRomeo
    Member
    Apr 27, 2009
    17
    I don't think the load should affect what's going on inside uC. More likely it has something to do with the surrounding hardware that can't quite cope with the load. Post your schematics and call in the EE's :)
  3. Tahmid
    Jul 2, 2008
    344
    27
    Which Pic Micro controller have you used? What Modulating frequency you have used?
    It seems that may be proper feedback is not utilized in your Code and that is why, with full load, harmonics increase and sine wave signals distorted.
  4. praveen_palaparthi
    Sep 30, 2009
    Hello
    Here i am sending the output sensing schematic this is the circuit
  5. rjenkins
    Nov 6, 2005
    1,015
    69
    You are storing the ADC reading as out_voltage but comparing the sine ref to out_voltage_1, are you transferring the value somewhere else or is this a mistake?
    Also, you appear to be comparing the two without regard for which half of the sine wave you are in? I believe you may need to invert the result (X) during the negative half.
