Help required for programming Link list in c++
Discussion in 'Programmer's Corner' started by RRITESH KAKKAR, May 2, 2012.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    Hello everyone,
    I need help in programming the code for link list in C++, i have no software (compiler) and no deep experience in programming.
    so, please help me to start programming link list.
    i have seen tutorial on Google and on my book but i have not found the concept behind.
    like here:->
    s
    Code ( (Unknown Language)):
    1. truct node {   int x;   node *next; };
    2.  int main()
    3. {   node *root;       // This will be the unchanging first node    root = new node; // Now  root points to a node struct   root->next = 0;  // The node root  points to has its next pointer                    //  set equal to a  null pointer   root->x = 5;     // By using the -> operator, you  can modify the node                    //  a pointer (root in this case)  points to. }
  2. debjit625
    Apr 17, 2010
    790
    185
    To understand the concept of Link List in C\C++ you have to understand the concept of pointers. So before explaining anything I would like to know do you understand pointers well enough?
    What software compiler??? C\C++ compiler, their are many like open source MinGW with Code::Blocks as IDE or you can use Visual C\C++ compiler, from Microsoft’s website you can download the latest version i.e.. Visual Studio 2010 (Express Edition is free).Or you go for Borland C\C++ compiler.
    Good Luck
    RRITESH KAKKAR likes this.
  3. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Thanks for replying, will Dev c++ will work fine.
    and i am not strong in programming whether its pointers. please guide me..!!
  4. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I have seen this it was file of Gb's, so i ned link for down loading small Compiler software..!!
  5. cheezewizz
    Apr 16, 2009
    82
    10
  6. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    OK, The software has been downloaded so, please guide me how to start single link list program in C++...?
  7. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    OK, I am using DEV C++, it is showing error source file not complied...
    code is:->
    1. #include <iostream>
    2. int main()
    3. {
    4. using namespace std;
    5. cout << "hey";
    6. system("PAUSE");
    7. return 0;
    8. }
    and error listed below are.
    i:\gw\lib\crt2.o(.text+0x8) In function `_mingw_CRTStartup':
    [Linker error] undefined reference to `__dyn_tls_init_callback'
    [Linker error] undefined reference to `__cpu_features_init'
    i:\gw\lib\crt2.o(.text+0x8) ld returned 1 exit status
  8. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    OK, now ia m using code block and it is working fine for me..!!
    So, please start with programing of single link list.
  9. stahta01
    Member
    Jun 9, 2011
    133
    21
  10. debjit625
    Apr 17, 2010
    790
    185
    You have to learn about pointers before learning about Link List... its like before learning to write we learn ABCD...
    There is internet, and some good books too like
    "Thinking in C++ by Bruce Eckel"
    "C++ A Beginner,s Guide by Herbert Schildt"
    or by the inventor of the C++ language himself "The Design and Evolution of C++ by Bjarne Stroustrup"
    And any compiler will work, as they all compile the code to native machine language, some compiler don't obey the standards, so whatever compiler you use just follow the standard coding practice. While you are learning you don't have to bother about standards.
    Your code didn't work because of improper declaration of namespace. It should be like this
    Good Luck
