Help required for power loss and undesired waveform
Habib Ali
Joined Jul 16, 2010
Hello
I have designed a dc to dc converter in push pull configuration . the problem is that when the input power is about 54 watts the output is about 7 watts. when I studied the wave form , I observed that when the gate drive is off the drain fall to 0Volt for some time. if any one can help we can send u the waveforms or the waveforms are at the link
http://www.maxim-ic.com/app-notes/index.mvp/id/3835
hgmjr
Joined Jan 28, 2005
9,027
If you can attach a detailed schematic here in this post our members can better assist you with your questions.
hgmjr
