help required for optocoupler
Discussion in 'General Electronics Chat' started by syed hassan, May 21, 2015.
  1. syed hassan
    Mar 11, 2015
    13
    hi every one i am a new user of optocoupler pic817 and for my pwm based h-bridge driving circuit i am using it.. is it a right choice for this circuit?...or should i need to replace it with some other package?
    one more thing that i want to clear is,currently i am using emiiters output which is being further fed into buffer . so what if i take output from collector?
    my circuit diagram is given in attachment
  2. wayneh
    Sep 9, 2010
    12,394
    3,246
    What is the purpose of the resistors in parallel to the emitter LEDs?
    You can use the collector as the "output" if you move the resistors to the high side. I believe this might give a better signal but the logic will be reversed.
  3. ian field
    Distinguished Member
    Oct 27, 2012
    4,459
    792
    The whole point of an opto-isolator is that the output transistor is floating, you can tie the emitter to ground and the collector via a load resistor to +V, or tie the collector to +V and take the output across an emitter resistor.
    You can look at it in the same way as the difference between common emitter and emitter follower - common emitter is inverting, emitter follower isn't. Except the input needs more Vf to turn the LED on, and the input and output are isolated.
  4. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    I use the MOC8106, also go direct from PIC to opto to Ir2110.
    Max.
  5. Stuntman
    Mar 28, 2011
    189
    50
    Side note I see no need for R7 or R10 (barring serious ground loop issues). Remember, the LED inside still has a Vf. That said, I don't see your Vdd and Vss connections for the MCU or any decoupling.
    Your setup may work just fine using the collector, as ian field explained, the transistor is floating. That said, I have generally used them as open collector outputs, at the expense of inverted logic.
  6. ian field
    Oct 27, 2012
    4,459
    792
    Most of the safety rated opto-couplers used in the regulation feedback isolation on SMPSUs have no external connection to the base terminal.
    To all intents and purposes, the transistor in such units is a two-terminal device - it is polarity concious though.
    Years ago I had a magazine project published for a test set for no base opto-couplers.
    Since its possible to invert the basic PUT relaxation oscillator and use a TO 92 SCR instead, I made it dual purpose - the pulse generator SCR was also socketed so it could also be used to test the SCRs.
    For a while, TO92 SCRs like the 2N5061 were popular in latching shutdown circuits on TV sets.
    Stuntman likes this.
  7. Stuntman
    Mar 28, 2011
    189
    50
    I actually had no idea there were optocouplers that HAD external base connections. PS2501's have historically been my goto.
  8. ian field
    Oct 27, 2012
    4,459
    792
    There was a rise in the popularity of the ones like a 4-pin DIL chip, the original 6-pin DIL types used to have a base connection, but as new safety regulations came into force, many types without were introduced. A lot of the safety types also have the pins stretched out wider than the usual 0.3".
  9. Sensacell
    Jun 19, 2012
    1,184
    277
    Opto couplers are pretty darn slow, not good for high frequency H-bridge applications.
    ranch vermin likes this.
  10. kubeek
    Sep 20, 2005
    4,691
    806
    Not all of them, the digital ones with gate at the end can be pretty fast, and some even contain power drivers like the HCPL3120.
  11. syed hassan
    Mar 11, 2015
    13
    thanks all of you for your concern and replies
  12. syed hassan
    Mar 11, 2015
    13
    then what do you suggest? what i should i use instead of an optocoupler?
  13. shortbus
    Sep 30, 2009
    4,096
    1,692
    @kubeek, is there a way these can be used with a 'high side' mosfet?
  14. kubeek
    Sep 20, 2005
    4,691
    806
    A standard bootstrapped high side driver configuration will work, similar to how IR2110 and others are configured.
    shortbus likes this.
  15. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    Compare the rise and fall times, the one you selected appears to be 18us, the MOC8106 is a little faster.
    Max.
  16. ian field
    Oct 27, 2012
    4,459
    792
    What pulse frequency? You might just about get away with 100kHz, you may be able to get Schmitt-triger input type MOSFET drivers that clean the pulses up a bit.
    Don't use Darlington type opto-couplers - they're even slower than straight bipolar transistor types.
    Before giving up - look at the data sheets for some MOSFET output optos, I don't know off hand whether they're faster but it wouldn't hurt to look.
    The MOSFET ones are quite popular in telecoms applications.
