Hi I have a post open in the projects forum to make a 4x4 matrix switcher
I read that eagle is a good start for the pcb layout so I am using 5.11
I am looking for help and guidance on the layout.
I am using a 4x max4314 and a 4093b for the switching using a single deck rotary switch.
Datasheet for maxin max4314
http://datasheets.maxim-ic.com/en/ds/MAX4310-MAX4315.pdf
Datasheet for the CD4093
http://www.datasheetcatalog.org/datasheets/270/109356_DS.pdf
Forum post is
http://forum.allaboutcircuits.com/showthread.php?t=53286
I have not added the power bus,ground etc
I am not sure the best way to connect the switches to the pcb so any suggestions are welcome.
I am in japan so some things are a bit hard to get or have different names
I have attached the schematic and board in eagle format.
I tried to convert the schematic to pcb but it went horribly wrong
Forum post is
