Help request
Discussion in 'The Projects Forum' started by Boniface, Jul 11, 2010.
  1. Boniface
    Jul 8, 2010
    Thank you for having made me a member in this great forum, i am glad. Pls, is it possible to charge battries with an inverter output in order to make it ready for use after the others are down. Thank you.
  2. windoze killa
    Feb 23, 2006
    605
    24
    This seems like a pointless exercise. You want to charge batteries using an inverter that is being run off batteries. Taking into account the inefficiency of the inverter you would never get the batteries charged to a level near the where the other batteries would be starting from. This is actually a negative process.
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    Are you asking whether once mains power is restored, can a UPS inverter be "run backwards" to recharge the batteries? UPS units generally contain battery chargers, but it is not as simple as adding mains power to the AC output terminals of a simple inverter and getting 12V DC out the other terminals.
    What are you trying to design?
    John
