Here is the scenario. I have 7 zone valves operated on 110V for my hydronic heating system. They are all powered individually and controlled by thermostats. What I want to do is to be able to turn on a pump when one or more of the thermostats is calling for heat. My problem(?) is that if I wire all of the zone valves through to the pump, all of the valves will open when one is energized. What I was thinking (and I could be way off here) is to put a diode in each line between the zone valve and the pump. It is my understanding that the diode will only allow current to pass one way, thereby preventing the other valves to be energized. The total load of the pump is 25W - 70W.
Am I on the right track?
Is there a specific type of diode I should be using?
Is there a size of diode I need?
Where to find such a beast?
Any help and or suggestions would be greatly appreciated!
Lano in Canada
Lano in Canada
