Ok repair low voltage power supply, but
moving the vertical position of the potentiometer track and off-center shifts of 2 cm. The display is a maximum of about a major division (about 1 cm), both channels are the same. The rest looks good. I schematic. tensions are OK. Tension is high as -3,000 said. I can trace the signal through the amp vertical and is approximately 2 times the size in a different area. I can find the same signal on the next card that is connected by a coil large screen.
and it is possible that the IC hibrid 5081-3024? how can I do to make sure the fault I found the resistance 31.6 ohms hot unsolder the circuit still measure 32.8 ohms.
thanks
Any ideas or help would be welcome.
Ascolta
Trascrizione fonetica
http://www.google.it/dictionary?source=translation&hl=it&q=&langpair=
thanks
Ascolta
