Help - Relaying a switched motor
Discussion in 'The Projects Forum' started by 4ePikanini, Feb 6, 2012.
Thread Status:
Not open for further replies.
  1. 4ePikanini
    Feb 6, 2012
    Hi
    I'm busy rebuilding my father's car and the window winder cables and connectors are a bit old. They work fine but very very slow due to voltage drop.
    I have checked direct power to the motors and then they run like mad!
    Instead of redoing all the wiring and connectors - I tried cleaning contacts - doesn't work - I want to run power direct from the battery to the motor and have the original wiring just switch a relay.
    Sourcing new power to the start of the window winder switch is not going to work eithe as that switch is pretty old as well and gives a bit of voltage drop as well.
    Now....
    The motor is not grounded. It has two wires coming from it.
    If you connect them 12v - Ground - they go up
    If you connect them Ground - 12v - they go down
    So. I can relay them but in my mind I only see a 6 relay option per door with a large amount of wiring.
    Is there a simple way of doing this? I understand relays but I can't wrap my head around this one to find a simple elegant solution.
    Your help in this is much appreciated. Thanks in advance.
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
Thread Status:
