help regarding single rail opamp use
Discussion in 'General Electronics Chat' started by ashrok, Feb 22, 2009.
  1. ashrok
    Feb 22, 2009
    13
    hi all,
    i need help in opamp usage,
    I'm using this LM741 in single 5V supply..The purpose is to shift the DC level of input signal.
    If the signal is 5Vpp wit DC value at 0V(from -2.5 to +2.5V).
    I shd shift this signal to +ve side b/w 0 and 5V with DC at 2.5V..
    Is this possible?
    if not, is there any other way to do this,
    pls help
    thanks in advance,
    A
  2. mentaaal
    Oct 17, 2005
    451
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    You'll need to use a different op amp, that is way under what a 741 can use for power supply. A LM324 might work.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    You won't get there using a 5v supply with an LM741. If you're lucky, you might get 1v peak to peak output with a 5v supply. LM741's were the greatest thing since sliced bread, when they were introduced some 40+ years ago. They are still around because professors like to punish their students with them. ;)
    Increase your Vcc to 10v, or use an opamp that has rail to rail inputs and outputs, like an LM6132.
  5. mentaaal
    Oct 17, 2005
    451
    I hear that! I am one of those students!
    Our lecturer had marked vcc and ground pins wrong on our schematics and in the space of a few minutes a whole class's worth of opamps were blown!
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    There bye allowing him to buy new op amps, or get closer to that goal.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Nope. Voh for an LM324 is Vcc-1.5v for a 2k Ohm load. He'd need an absolute minimum Vcc of 6.5v.
  8. ashrok
    Feb 22, 2009
    13
    hey thanx a lot guys..i cant believe i missed out such a simple concept of summer.
    thanx again..
    yes i had some doubt about using lm741(went ahead as v had worked wit tis IC in all the labs)..
    i'll chk out on lm324.
  9. ashrok
    Feb 22, 2009
    13
    actually i cant use supply voltage greater than +5V. We take power from USB port of the PC. so max allowed is +5V. that is why we thought of using the op amp in single rail mode.
  10. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Take a look at ICL7660 and MAX1044 IC's; they are CMOS switched-capacitor voltage converters. They can give you a low-current dual +5v/-5v or +10v supply from a 5v source.
    http://pdfserv.maxim-ic.com/en/ds/ICL7660-MAX1044.pdf
