help regarding atmel 89c51 micro controller
Discussion in 'Programmer's Corner' started by shiva21h, Apr 9, 2007.
  1. shiva21h
    Apr 8, 2007
    hi,
    i have written a program and i want to feed that data into Atmel 89c51 micro controller. i don't know how to feed data into it.
    can you suggest me how to insert the data into the controller.
    what all hardware and softwares required ....
    could you please help me in this .....
    could you also tell that were can i get the required hardware( serial port) and software.
    cheers
    regards
    shiva
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    You will need something similar to this 89C51 programmer to download the hex code file into the device over your PC's serial port.
    The assumption is that your code development software already has created the downloadable file in the proper format.
    You can google for other programmers that are on the market.
    hgmjr
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Have you looked at the material on the Atmel website? They make the device, and are reasonably familiar with how to use it. As you say you have written a program, you may need to find a programmer for the 89c51. Atmel makes several.
  4. shiva21h
    Apr 8, 2007
    hi,
    thanks for the information.
    i will go through the site and order the kit...
    thank you very much...
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    Make sure you check into the programmer board before you commit to a purchase to make sure that it has all of the feature you will need to meet all of your programming needs.
    hgmjr
  6. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Many Atmel parts are designed with a bootloader and can be programmed repeatedly after being installed on a board. No need to buy a programmer if you have one of these.
