Help rearranging an equation
Discussion in 'General Electronics Chat' started by Ronscott1, Nov 10, 2009.
  1. Ronscott1
    Nov 5, 2009
    15
    Here is the original equation:
    Ie = Vcc - Vbe / ((Rc+Re+Rb) / Bdc)
    I need to solve for Rb. Could you guys help me?
    Best,
    Ron
  2. someonesdad
    Jul 7, 2009
    1,585
    141
    Rb = [(Vbe*Bdc)/(Vcc - Ie)] - Rc - Re
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    I think your starting equation is incorrect - probably just misplaced parenthesis.
    Assuming you have made the approximating assumption Beta = (1+Beta)
    I would have written
    Ie = (Vcc-Vbe)/(Rc+Re+(Rb/Beta))
    or more correctly (i.e. not using the approximation)
    Ie=(Vcc-Vbe)/(Rc+Re+(Rb/(1+Beta))
    To re-arrange the approximate version
    Ie(Rc+Re+Rb/Beta)=Vcc-Vbe
    Rc+Re+Rb/Beta=(Vcc-Vbe)/(Ie)
    Rb/Beta=(Vcc-Vbe)/Ie-(Rc+Re)
    Rb= Beta(((Vcc-Vbe)/Ie)-Rc-Re)
  4. Ronscott1
    Nov 5, 2009
    15
    Thank you someonesdad
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    While someonesdad has correctly re-arranged your equation it should be pretty obvious that the term
    is not a resistance - it's a nonsense.
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    I'll write it nicely...
    I_e = \frac{V_{cc} - V_{be}} {{R_c+R_e+} \frac{R_b}{1+\beta}}
    Hand Waving here.... (See t_n_k's post)
    Rb=\beta (\frac{V_{cc}-V_{be}}{I_e})-Rc-Re
    Readable is good. Click on the Ʃ in reply box to get the Tex Editor/helper.
  7. Ronscott1
    Nov 5, 2009
    15
    T_N_K,
    When I set my work up using your equation I am getting very different results from what I calculated before and what multisim is telling me. However when I drop that pair of parenthensis I am getting similar answers. I do not have a scanner so I cannot scan my schematic or calculations
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    How about ....???
    Rb=\beta(\frac{(Vcc-Vbe)}{Ie}-Rc-Re)
  9. Ronscott1
    Nov 5, 2009
    15
    I will post my work tomorrow when I get to school and have access to a scanner but thank you guys so much for you help
  10. t_n_k
    Mar 6, 2009
    5,448
    783
    Is this what we are imagining?
  11. thatoneguy
    Feb 19, 2009
    6,357
    718
    My bad for getting the parenthesis wrong:
    \large{Rb=\beta (\frac{V_{cc}-V_{be}}{I_e}-Rc-Re)}
    It looks correct to me. :confused:
  12. Ronscott1
    Nov 5, 2009
    15
    t_n_k,
    That is exactly what I am working on that same exact circuit. I was given the problem to design the resistor values Rc, Rb, and Re to meet the following specifications:
    Vcc=9V
    Vce at midpoint
    Ic=1 mA
    βdc=300
    Here is my work until the point we are at now:
    Ve=0.1*Vcc
    Ve=(0.1)(9V)
    Ve=0.9V
    Re=Ve/Ie Since Ie≈Ic
    Re=0.9V/1mA
    Re=900Ω
    Rc=4Re
    Rc=4(900Ω)
    Rc=3.6kΩ
    And here is where I got stuck. I am following VDB guideline from Albert Malvinos Electronics Principles Book.
    Is there something that I am doing wrong? If so how should I go about calculating these resistor values?
    Best,
    Ron
  13. Ronscott1
    Nov 5, 2009
    15
    In other words, Are there certain steps that someone should take when designing a collector-emitter feedback amplifier? Please help
