Help reading relay labels
Discussion in 'The Projects Forum' started by Justin Frank, Dec 21, 2015.
  1. Justin Frank
    Dec 21, 2015
    Hello! I found this relay with these specifications printed on it and was wondering if anyone knew what they mean. Thanks!
  2. Justin Frank
    Dec 21, 2015
  3. strantor
    Oct 3, 2010
    4,302
    1,989
    A and B is the coil.
    7 is the common
    5 is the Normally Open
    2 is the Normally Closed
  4. Justin Frank
    Dec 21, 2015
    Thank You! What do all the listed Voltages and currents mean?
  5. crutschow
    Mar 14, 2008
    13,511
    3,385
    The first is the coil voltage and frequency.
    The second is the maximum 120VAC contact resistive load.
    The third is the maximum 28VDC contact resistive load.
    The fourth is the maximum 120VAC contact motor load.
    The fifth is the maximum 240VAC contact motor load.
  6. Justin Frank
    Dec 21, 2015
    Thanks!
