Help re-connect touch sensor to bedside lamp
Dannywh
Joined Mar 31, 2014
My problem is connection of different coloured wires to the new touch sensor in a bedside table lamp. This is the correct replacement unit.
The sensor has four wires - red, white, black, and yellow(which is the "earth" ).
Power input cable has two - blue and brown
Connection to the lamp(s) has two- red and white.
Please advise which colours are connected (via twist top plastic) to which.
Thanks in advance
DickCappels
Joined Aug 21, 2008
10,187
I am tempted to make a guess based on standard color codes, but there would a good chance that trying that you would blow up your new touch sensor. I think it would be best for you to contact the lamp manufacturer for the details of how to connect your sensor.
Metalmann
Joined Dec 8, 2012
703
"My problem is connection of different coloured wires to the new touch sensor in a bedside table lamp. This is the correct replacement unit."
If it's the correct unit, can you not contact the MFGR?
