[HELP] pulse generator atmega8535?
Discussion in 'Embedded Systems and Microcontrollers' started by ekun69, Oct 7, 2009.
  1. ekun69
    Oct 7, 2009
    need help,, how to make pulse generator with atmega8535? is it enought just to out 1 and 0 sequensially on the output port?. i use this pulse generator to operate stepping motor,,
    thanks..
  2. KitCarlson
    Member
    Sep 27, 2009
    13
    To start, read about the timers and output compare functions.
    What compiler are you using?
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    The Atmega8535 has the power to produce a pretty accurate pulse. As kitcarlson has stated, you need to immerse yourself in the data sheet to gain the understanding you will need to tackle the task of programming the AVR to create the pulse. You will most likely need to get acquainted with the interrupt features of the AVR.
    hgmjr
