Help !Pspice amplifier calculate voltage gain ????
Discussion in 'Homework Help' started by Judas543, Feb 3, 2010.
  1. Judas543
    Jan 26, 2010
    60
    So my question is how to calculate the voltage gain for the amplifier? and the ratio of the voltage amplitudes? Is their a formula or just by reading the graph..
    Schematic + Problem:
    My Graph:
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    I don't know if the input is 5mV RMS, 5mV peak or 5mV p-p.
    You can calculate the gain if you calculate the value of the internal emitter resistance of the transistor and the parallel combination of the 2k collector resistor with the 10k load resistance.
  3. Judas543
    Jan 26, 2010
    60
    the input of VAMPL is 5 mV. SO what would be the solution so i can solve another problem similar to this. Thanks i appreciate the help
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    But you and your teacher do not say if the input is 5mV RMS, 5mV peak or 5mV p-p. They are all different levels.
  5. Judas543
    Jan 26, 2010
    60
    which input X_X??? could you point out which one?
  6. JoeJester
    Apr 26, 2005
    3,401
    1,218
    I always understood it to be rms unless pk-pk or 0-pk is specified.
