Help Proteus Package
Discussion in 'General Electronics Chat' started by brian25, Mar 22, 2014.
  1. brian25
    May 13, 2013
    i want to make new device in proteus but i don't know when to use the electrical types configuration (passive, input, output, pullup etc..)
    example if i want to make device Q4004l4(triac)....... where should be the passive, input and output pin here?
  2. t06afre
    May 11, 2009
    Then working with ECAD system. You can cut a lot of corners by using existing components as template for new components. So see how Proteus has solved this by looking at an existing triac library component.
