help project in industrial electronics
Discussion in 'The Projects Forum' started by yhandz, Feb 9, 2010.
  1. yhandz
    Feb 24, 2009
    12
    can you help me have a circuit diagram of my project.. requirements needed in the project is 3 different kinds of sensors( ex. light, infrared, temperature), thyristor motor and bulb...
    note: other sensors can be used like humidity, sound, motion, and other sensors...
    i'm thinking of project such as burglar alarm, fan controller and others... an also if possible the project would be pure hardware (what i mean is no programming involve)
  2. williamj
    Sep 3, 2009
    180
    32
    What is it you want to accomplish?
    williamj
  3. andreapg
    Feb 2, 2010
    41
    It sounds like an home automation projet. I presume you need to build a board which drives 3 different functions.
    A question: must the burglar alarm have a number combination?
  4. yhandz
    Feb 24, 2009
    12
    it's ok if there's no number combination... there will be just a buzzer
  5. yhandz
    Feb 24, 2009
    12
    in my idea of fan controller i want to have infrared sensor to know if someone is in the room then the bulb will turn on then the temperature sensor will let the fan turn on while using the light sensor it will turn of if there's no person anymore...
    (note: the project will also have motor and thyristor)
  6. andreapg
    Feb 2, 2010
    41
    About motion sensors do you mean earthquake detector?
    (search for "earthquake motion sensor", "speed motion sensor")
    What is a thyristor? (not found in WordReference)
    About light sensor you may build a photoswitch relay using a photoresistor and a 555IC.
  7. yhandz
    Feb 24, 2009
    12
    motion sensor is just an example.. examples of thyristor is triac, diac, scr, etc.
  8. t06afre
    May 11, 2009
    5,939
    1,222
    What are you looking for? A complete project you can deliver as homework in your own name, or something else? Please explain what you are looking for?
  9. yhandz
    Feb 24, 2009
    12
    yep... a complete project.. it's our industrial electronics project
  10. t06afre
    May 11, 2009
    5,939
    1,222
    We do NOT do others homework in this forum. But you are welcome to post any questions regarding any topics in your project. Also remember to include any schematics you may have then asking questions
  11. Wendy
    Mar 24, 2008
    20,772
    2,540
    As t06afre said, we will gladly help if you post a schematic, with critique and corrections.
  12. t06afre
    May 11, 2009
    5,939
    1,222
    Of course I could do the job for you, but that will require a signed contract and a fee. In other words the project would have been done like any other outsourced industrial electronics project, with the equal cost also. So it is your call ;)
  13. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The idea of your assignment is that you will learn something by designing it yourself.
    If someone just handed you a completed project, you would not learn anything.
  14. atferrari
    Jan 6, 2004
    2,663
    784
    Prior signing a contract with the OP, please consider that the graduation ceremony where you should receive his degree, will be held at Cebu, not around the corner, precisely. Include the ticket / hotel / meals etc in your expenses. :eek:
    Or make a safe lumpsum quotation (risk is yours).:D
