help......problem with lcd
Discussion in 'Embedded Systems and Microcontrollers' started by h.d, Mar 1, 2008.
  1. h.d
    Thread Starter Active Member
    Oct 22, 2007
    150
    hi
    i tray to display values on lcd but there are problem
    please see the code and the output
    and please help........
    the code in mBASIC
    program lcd1test
    dim x,y as byte
    dim x1,y1 as string[3]
    main:
    lcd_config(portb,7,6,5,4,portb,1,2,3)
    lcd_cmd(lcd_clear)
    lcd_out(1,1,"timer")
    lcd_cmd(Lcd_Cursor_Off)
    lcd_out(1,8,"km/h")
    lcd_out(1,14,"km")
    lcd_out(2,8,"18")
    lcd_out(2,14,"25")
    for y=0 to 60
    bytetostr(y,y1)
    lcd_out(2,0,y1)
    for x=0 to 59
    bytetostr(x,x1)
    lcd_out(2,3,x1)
    delay_ms(1000)
    next x
    next y
    end.
  2. Nandini
    Jul 10, 2007
    i can guide you in assembly as i dont know mbasic
  3. h.d
    Oct 22, 2007
    150
    ok,no problem
    i know some assembly,plz help if you can.
