Help, potential of a coaxial.
Discussion in 'Homework Help' started by lam58, Dec 29, 2014.
  1. lam58
    Jan 3, 2014
    69
    The question asks to find the potential of a the ungrounded outer conducting sheath of a coaxial cable when the inner conductor has a voltage of \frac{220}{\sqrt{3}} kV.
    Coaxial conditions:
    i) Central copper conductor of diameter 4.8 cm.
    ii) Insulating layer of XPLE of thickness 2.3 cm and relative permittivity k = 2.2.
    iii) Conducting lead sheath of thickness 2.9 mm.
    iv) Insulating HDPE layer of thickness 5 mm and k = 2.4.
    v) Outer coating negligible thickness in contact with soil.
    My attempt:
    I found the XPLE to have a capacitance of 310.70x10^-12 F/m.
    To find the potential I assumed the charge between both conductors would equal 0, thus the charge on the inner conductor = -'ve charge on sheath. Hence I can use Q = CV to find the charge:
     310.73x10^{-12} * \frac{220}{\sqrt{3}} = 3.95x10^{-5} C
    Then to find potential between the two I use:
     v = \frac{-Q}{2\pi\epsilon_0\epsilon_r}.ln(b/a)
    \Rightarrow v = \frac{-Q}{2\pi * 8.8x10^{-12} * 2.4}.ln(0.0789/0.0739) = -19.5 kV
    Which implies the potential on the lead sheath = \frac{220}{\sqrt{3}} kV + -19.5kV = 107.5kV
    Have I done this right?
