Help pleaseeeeee in designing convertor
Discussion in 'The Projects Forum' started by AaraAbdas, Dec 21, 2012.
  1. AaraAbdas
    Dec 11, 2012
    5
    I m trying to design buck-boost convertor controlled by PIC controller. PIC is simply generating a pulse for switching. I m unable to understand why the output is not coming right. for duty cycle I used the formula D= Vo/(Vo-Vi) and frequency of pulse is 21Khz.
      File size:
      29.6 KB
      18
  2. spinnaker
    Oct 29, 2009
    5,115
    1,195
  3. kubeek
    Sep 20, 2005
    4,691
    806
    Maybe try using some base resistors for the transistors.
    Also saying waht you get and what you expected might help.
