help please
Discussion in 'The Projects Forum' started by jj1960, Feb 12, 2013.
  1. jj1960
    Feb 4, 2013
    hi
    i have a umt500mh cycle timer which has a output rated 5amps @ 240ac , i need to add a relay rated at 20 /25 amps can anyone advise of a cheap and cheerful relay that i could use and also how i connect this to the timer and then a mains 3 pin socket
    thanks
  2. t06afre
    May 11, 2009
    5,939
    1,222
    That is a lot of current. Strictly speaking this is something you should not do unless you are certified to do such work. Before we resume. You should tell us what you are trying to do in more details
  3. jj1960
    Feb 4, 2013
    what i want to do is cycle on / off a 600w light and 2 fans, the amp rating is overkill but i would have thought the higher the rating the longer the contacts will last
  4. praondevou
    Jul 9, 2011
    2,936
    489
