In part this is correct - at least at resonance in a series LC circuit the effective impedance becomes equivalent to a resistance. If L & C are ideal then the effective resistance would be zero at resonance. But just replacing L & C with a resistance does not give an equivalent circuit at all other frequencies. For instance, a series LC circuit will not pass continuous DC current, whereas a resistor will. At all other frequencies the impedance is reactive - increasingly inductive above resonance and increasingly capacitive below resonance.as far as the generator is concerned, in a series-resonant LC circuit(with no resistor), L and C can be replaced by a resistor with the same value of L x C?
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Jake Hertz
