Help please.
Discussion in 'Homework Help' started by Rock33y, May 21, 2008.
  1. Rock33y
    May 21, 2008
    How do you find the equivalent resistance of a circuit? :confused:
    Thanks in advance.
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    By reducing series and parallel combinations down to a single resistance between a pair of nodes.
  3. Rock33y
    May 21, 2008
    sorry don't really get your explanation..:confused: I was trying to solve this:
    A 7 ohm, a 1 ohm, and a 10 ohm resistor are in series. This series combination is then in parallel with a 6 ohm resistor. The combination of four resistors is then in series with a 10.3 ohm resistor. A 20 V battery is used. What is the equivalent resistance?
    If you can explain the above question, it'll be much appreciated
  4. Caveman
    Apr 15, 2008
    471
  5. Rock33y
    May 21, 2008
    okay so im using this: [​IMG]
    what operation do you use with the R1 and R2.. (aside from the addition one).
  6. mik3
    Feb 4, 2008
    4,846
    63
    On the numerator you multiply R1 by R2
  7. hgmjr
    Jan 28, 2005
    9,030
    214
    You can also read the material on series and parallel circuits here in the AAC ebook.
    hgmjr
  8. Caveman
    Apr 15, 2008
    471
    Is this an algebra question? You just substitued R1, R2, and R3 into the equation and get Req.
  9. Rock33y
    May 21, 2008
    thanks for all the help.. the answer is suppose to be 14.8 ohm.. :confused:
  10. JoeJester
    Apr 26, 2005
    3,387
    1,211
    the answer is 14.8
    Show your work and then someone can tell you where you went astray.
  11. Papabravo
    Feb 24, 2006
    10,338
    1,850
    I prefer to answer your PM in the open forum so others may benefit.
    Your explanation of the question was just fine. I don't know how much plainer my answer could have been. In the thread above there is a relationship for two resistors in parallel. This relationship can be applied recursively to any number of resistors in parallel. There is also the following relation
    Code ( (Unknown Language)):
    1.
    2. For n resistors in parallel R1, R2, ..., Rn.
    3. The total resistance Rt, is given by
    4.
    5. 1/Rt = 1/R1 + 1/R2 + ... + 1/Rn
    6.
    If you really want to impress your friends at cocktail parties you can refer to this as adding conductances measured in mho which is ohm spelled backwards.
    Another fun factoid is that in any parallel combination the total resistance is always strictly less than the smallest resistance on any branch.
