Help please with Led sequencer for my shop.
Wendy
Joined Mar 24, 2008
23,421
OK, finished helping another thread I was doing some drawings for. I'll sketch something else up here next.
Wendy
Joined Mar 24, 2008
23,421
OK, here is how I would do it...
Depending on the exact Vf of the LEDs would determine with block schematic you would use (shown on bottom of drawing).
Drawing corrected.
brozizds
Joined Aug 15, 2010
135
Hi Guys,
What kind of transistors are being used in this circuit? Howdy Bill I'm kinda following this thread and going to proto board when your are done ( for another project) lol Thanks Jim;)
Wendy
Joined Mar 24, 2008
23,421
Anytime I don't specifically name a BJT you can bet it is either a 2N2222A or a 2N2907A, depending on polarity. The ones in a metal case can handle 0.6 W, and they have fairly gain.
Wendy
Joined Mar 24, 2008
23,421
The transistors in question are NPN, 2N2222A. Plastic types (AKA PN2222A) will work fine for this application. Radio Shack sells a 15 pack for a fair price (unusual for the shack).
I need a firm Vf for the LEDs you have. You probably need to measure them, this I can help with too. Then I can define those blank resistors on the schematic.
What kind of board are you planning on using to build this?
SgtWookie
Joined Jul 17, 2007
22,230
The 15 NPN transistor assortment that Radio Shack sells usually contains:
5 - 2/PN2222 transistors
5 - 2/PN4401 transistors
5 - 2/PN3904 transistors
Wendy
Joined Mar 24, 2008
23,421
They are pretty interchangeable, though I prefer the PN2222A types (better specs). I bought a package of a 1000 from BG Micro not too long ago.
To the OP, when you refer to the PCB, I'm more curious about the display unit and how you are going to do that. The breadboards Radio Shack sells will work OK for the electronics. I tend to draw the circuits, I can do it here, though it will take a while.
If you have never done this kind of work it will be the hardest part.
Wendy
Joined Mar 24, 2008
23,421
Drawing circuit boards takes a lot more patience than schematics (for me). I've gotten pretty good on both. Lots of practice, don'tcha know.
