Help please with confusing LED question
Discussion in 'The Projects Forum' started by Zilikken, Aug 20, 2012.
  1. Zilikken
    Jun 18, 2012
    I am new to all of this. I am doing a project that require 13 LED's, most of them are blue and hooked up to a 9v battery via parallel with each parallel a series of 2 LEDs. I have most of them hooked up but when I connect one single white LED all of the other blue LEDs turn off and only the single white LED is on. Now I don't think I am doing anything wrong, I am connecting it to the rig like the other LEDs.
  2. #12
    Nov 30, 2010
    16,661
    7,305
  3. JDT
    Feb 12, 2009
    658
    85
    I think it is because all your LEDs are in parallel.
    Wire so that each LED has it's own series resistor from the 9V supply.
  4. gerty
    Aug 30, 2007
    1,154
    304
    Can you post a drawing of what you have and how it's connected.
    That'll make it easier to help
  5. ramancini8
    Member
    Jul 18, 2012
    447
    119
    Apparently the white led hogs the current when you hook it up. Try a series resistor to limit the current.
