help please.. using the parallel port to turn on a solid state relay..
Discussion in 'Homework Help' started by blooandy, Jan 3, 2008.
  1. blooandy
    Jan 3, 2008
  2. mrmeval
    Distinguished Member
    Jun 30, 2006
    5v from a parallel port is perfect as the SSR you chose needs very little current on the DC side. But here's some parport info in case it's non-standard in some odd way.
    In fact I have an OMRON that draws so little I could piggy back an LED and it still worked.
    Should be 3-32 volts on the DC side and for the AC your line / mains voltage and rated at the max current of both devices + 25 percent. so 100 amp would need 125 amp etc
    There are calculations in the documentation that tell you how to figure out what resistor to use if you use a higher voltage than 3VDC for the control voltage. Damn good specs on those SSRs
    Pay attention to the heatsink requirements. Pay attention to the need for a snubber.
