Hello Everyone! Effects pedal project...I need help!! I have a 555 timer in astable generating a continuous 0 to 9V square wave to drive a 4017 decade counter. The 4017 resets on Q4 so I have 4 outputs of approximately 9V. What I want to do is use each of those to 'turn on' some type of circuit that will change the phase of a guitar signal, so that I will end up with 4 different phases of the input signal in a continuous sequence at the outputs. My question is, what type of phase shift circuit should I use and how do I pass the guitar signal ONLY through the circuit being powered by the 4017 output that is high.
I'm using LtSpice for simulation and have found one possible solution to my problem...I used a lm741 op amp in an all-pass filter circuit with a virtual ground so that the input signal wasn't above and BELOW 0V, causing the opamp to not work correctly, but even then, the only way I can get my desired output is to connect the positive side of the guitar signal to the filter input and connect the negative to the virtual ground, which I assume is just not an option in real life when I build my pedal. I have read something about AC-coupling to be able to connect input and output to real groud, while using the virtual ground in the op amp stage...
If you can't tell, I'm a total newb to circuit design, (I did take an electronics course at ATI about 7 years ago) so I'm sorry if I've said anything that didn't make sense, and please let me know if this project is just doomed to fail...I'm just trying to come up with a somewhat original effects pedal if possible. I would also be happy if instead of a phase shift effect, I could get an octave tone or some synth-type sound that changes with each 4017 output. Any help would be greatly appreciated. Thanks!
...I can attach an image of my ltspice schematic if it would help
