Help Please :D
Discussion in 'Homework Help' started by sh312, Dec 9, 2014.
  1. sh312
    Dec 6, 2014
    9
    Is anyone able to explain thevenin & nortons theorem to me?
    Thank you :D
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    sh312 likes this.
  3. sh312
    Dec 6, 2014
    9
  4. studiot
    Nov 9, 2007
    5,005
    515
    Well start by recognising that they are two different theorems not one single one.
    kubeek likes this.
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    This would be the Playboy version, where you look at the pictures instead of reading the articles.
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    Maybe it's like trying to explain to Boromir in simple terms why he can't take the ring back to Gondor.
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You mean because he's not a Hobbit?
    P.S. I thought it was Ned Stark
  9. WBahn
    Mar 31, 2012
    18,087
    4,917
    All Thevenin's and Norton's theorems amount to is that, for a linear circuit, the relationship between the voltage across any two points in the circuit and the current through those same two points (those two points are the "terminals") has a linear relationship that can be written as:
    Vx = Vth - Ix*Req
    This is the "load line" for the circuit between those two terminals.
    But this is exactly the same relationship that you get if you replace the circuit with a voltage source with an output of Vth in series with a resistance of value Req -- so these two circuits are equivalent as far as what happens between the two terminals.
  10. amilton542
    Nov 13, 2010
    494
    64
    If you're like me and you like to hear it "how it is" then pick up an industry standard reference book and memorise it word for word. That's what I do. But be warned, these books are only for the brave; not even a library will let you loan a reference book out. So I had to buy mine. I've always got a piece of paper squashed in my back pocket full of writing to memorise that I copied. My ambition? So long as I've got a chapter in a reference book with my name on it I'm happy.
