help-pic controlled cutter
Discussion in 'The Projects Forum' started by indika perera, Aug 3, 2014.
  1. indika perera
    Mar 7, 2013
    30
    hey..frds..i need an endless support from all of you to build an electronic elastic cutter that can cut elastic roll into lengthy pieces but it should be able to adjust size required length occasionally..also it should not be computer controlled but controlled itself using pic micro controller..so anyone experienced such circuit or having knowlege of building such circuit..plz help me to do my project..
    thank you..
    indi
  2. Dodgydave
    Jun 22, 2012
    5,141
    767
    Homework is it?
  3. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    One typical way it is done on a cut-to-length machine is to have a rotary encoder with rubber wheel ran on the material as it comes off the reel, the exact length is obtained from the encoder count and the shear or? is then operated.
    Max.
  4. Lestraveled
    May 19, 2014
    1,957
    1,217
  5. sirch2
    Jan 21, 2013
    1,008
    351
    Since this is for elastic I imagine the mechanical design will be interesting. There needs to be constant tension on the elastic as it is being measured or else the length of the cut piece would be variable.
  6. indika perera
    Mar 7, 2013
    30
    Thx...all
    yep i have intended to make some kind of cutter m\c(same as vinyl cutter) which is capable of cutting elastic into different sizes..i wanted to use stepper motor to get accurate measurement..
    thx you.
    indi
