help on tsop infrared receivers
Discussion in 'The Projects Forum' started by incubus, Mar 8, 2010.
  1. incubus
    Nov 22, 2009
    5
    Does anyone know what these figures say? Im a newbie and i know its very basic for you guys. thanks.
  2. R!f@@
    Apr 2, 2009
    8,791
    771
    that's the transmission lobe of a typical IR emmiter, is it not?
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    The graph shows that when the angle is zero then the range is 100%.
    When the angle is 45 degrees off center then the range is reduced to 50%.
    The graph shows the reduction of range at many angles.
