Help on transformers
Discussion in 'General Electronics Chat' started by Adamf001, Aug 28, 2012.
  1. Adamf001
    Sep 5, 2011
    67
    I'm building a bench power supply. I'm going to use two transformers one for the positive supply and one for the negative supply.
    my question is how does one get a negative supply from a transformer connected up to the mains. I've never really used transformers so I'm not sure the theory behind them... thanks
  2. Adamf001
    Sep 5, 2011
    67
    using two transformers how would I wire them to create a center tapped transformer like this one
    I think I remember someone saying it is possible but I'm not sure how it would work, any ideas?
  3. t06afre
    May 11, 2009
    5,939
    1,222
    Have you given the need for current any thought
  4. Adamf001
    Sep 5, 2011
    67
    I was just going to measure the amp value after I connect the transformers and make the alteration to my circuit depending on the current being supplied
  5. t06afre
    May 11, 2009
    5,939
    1,222
    Take a look at these PDFs. Use the "dual complementary rectifier circuit”
    Adamf001 likes this.
  6. crutschow
    Mar 14, 2008
    13,475
    3,362
    The DC output polarity is determined simply by the direction of the rectifier diodes.
    You can't easily "measure" the maximum rated output current of a transformer. It's determined by the design and its temperature rise due to current. The easiest way to determine the approximate current rating is to find a comparable size and voltage transformer in a manufacturer's catalog.
  7. vk6zgo
    Jul 21, 2012
    677
    85
    Only the last poster actually read your question!:D
    As he said,it just depends on which way round the diodes are connected.
    You are using one transformer for the positive supply,& one for the negative supply,so they are really two independent supplies.
    Use a bridge rectifier for each supply,& if you want them to have a common point ,connect the -ve output of the "positive" supply to this "common",& the +ve output of the "negative" supply to "common" also.
    Bridge rectifiers are commonly available in packages with the AC inputs marked with ,& the outputs with + & -.
    Google for "bridge rectifiers",and/or have a look in the "E-Book" associated with this forum.
    You also have to filter the output of each rectifier,to remove AC "hum",& probably also need to regulate the output voltages.
    Again,Google & the "E-Book" are your friends!
  8. Adamf001
    Sep 5, 2011
    67
    Yes you did thanks, using two transformers for me is much easier than using a centre tap transformer.
    I'll have to look out for the rectifier packs and search on my friend Google, my main goal was to have two independent power supplies, Thanks guys for your help :D
  9. t06afre
    May 11, 2009
    5,939
    1,222
    If the transformers are equal. You may connect the transformers secondary output in series. To create a center tap function
  10. Adamf001
    Sep 5, 2011
    67
    I was going to have a higher +v than -V so the transformers won't be equal and I can't seem to find anyone selling a decent centre tap transformer
  11. vk6zgo
    Jul 21, 2012
    677
    85
    He doesn't need a centre tap,as he has two separate transformers,& can use a bridge rectifier on each one.
  12. t06afre
    May 11, 2009
    5,939
    1,222
    Dude I know my way then it comes to this topic. The problem in this case as in many others. Is that the OP present information in small drip. Slightly changing the terms on the way.
    So to Adamf001. Let us cut to the chase. Just tell us something like this.
    I want to build a power supply. The voltage needed is plus xx volt, and minus xx volt. My estimated need of current will be xx ampere for the positive supply, and xx ampere for the negative supply.
    After this you write some words about what kind of equipment you want to connect to the power supply. Good questions draw good answers
  13. Adamf001
    Sep 5, 2011
    67
    ok ,
    I'm building a bench power supply, using LM337 and LM317.
    I'm aiming to get about +20 to +25V for the positive output
    and up to -15 to -20V on the negative output
    with no more than 1A from either output
    my original question was how using two transformers would I get a negative supply from one of the transformers... I've never gone into depth on the workings of transformers and bridge rectifiers
    I'm probably use two septate bridge rectifiers for each supply, I'd didn't know that the config of the diodes dictated the polarity of the supply. thanks to crutschow I now know, and thanks to t06afre PDF's I have a rectifier circuit that can give me negative supply from transformer.
  14. t06afre
    May 11, 2009
    5,939
    1,222
    This is something we can work with. Maybe in your case it will be better to build two separate LM317 based devices. Then put them together to create the +/- voltage. Like shown in the picture below.
    You will also need some cooling fins/ heat sinks on the regulator ICs. Your project is doable for a beginner. Given that you have some solder experience. How do you plan to mount the electronics. Will you be making a PCB. Or some sort of prototype board.
  15. Adamf001
    Sep 5, 2011
    67
    I think I know what you mean, I was going to build two separate supplies in one housing just like the pic one negative, the other positive, each connected to a analogue voltmeter
    I have a PCB development kit that I'm dying to use, and a box full of heat sinks
  16. t06afre
    May 11, 2009
    5,939
    1,222
    Just build two lm317 based units. Then you put them together to create the +/- voltage. Just as shown in the picture. Also feel free to post your PCB here for auditing.
    If you are a beginner in this field I would recommend it
  17. vk6zgo
    Jul 21, 2012
    677
    85
    The OPs original question was clear.
    Unfortunately,the second poster got the wrong slant on things & confused him with the comment about centre tapped transformers.
  18. Adamf001
    Sep 5, 2011
    67
    This is my initial design for the positive voltage regulator, I hope there are no major problems or I hope I haven't missed anything important, Thanks
  19. t06afre
    May 11, 2009
    5,939
    1,222
    As a tip draw the bridge rectifier as shown here http://en.wikipedia.org/wiki/Diode_bridge
    Also you need filter caps. Also mentioned in the wiki paper. The rule of thumb is 1000uF each of DC ampere output. However in your case I would have used the standard size 4700uF. And once again. Since you will not be using a centertap transformer. You will need to build two positive supply that you put together to a +/- supply
  20. szhighstar
    Jun 26, 2012
    27
    5
    it is a transformer with center tap, one is input winding, two are output winding, why will you select two transformers?
