help on simulation on pspice
Discussion in 'Homework Help' started by Ron Potashnik, Dec 27, 2015.
  1. Ron Potashnik
    Dec 27, 2015
    15
    hi. im trying to run the circuit the i attach.
    first off all i cant find the component CA3086. so im trying to build it like in the data-sheet, but it not working.
    can somone help me?
    Moderators note: show full image
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Here is a PDF from intersil with the spice model.
    Bertus
    PS I edited your post as you used an unwanted text.
  3. Jony130
    Feb 17, 2009
    3,990
    1,115
    Simply try to use a 15V zener diode and 6.8V Zener together with 2n2222 transistor .
  4. Ron Potashnik
    Dec 27, 2015
    15
    tnx i
    how do i use it?
  5. Jony130
    Feb 17, 2009
    3,990
    1,115
    This Spice model will not work properly with your circuit. Because I do not seen any Bv parameter.
  6. JoeJester
    Apr 26, 2005
    3,393
    1,211
    Looking at that schematic and looking at the diagram of the CA3086, which transistor is conducting?
    Moderators note: shown full image
    on edit ... showed the full CA3086 portion of that schematic
    [sarcasm] It must be a working circuit, after all, it's on the internet.[/sarcasm]
  7. Jony130
    Feb 17, 2009
    3,990
    1,115
  8. Ron Potashnik
    Dec 27, 2015
    15
    i also find this one that i think is good but i cant run it on the spice without any error
  9. Jony130
    Feb 17, 2009
    3,990
    1,115
    Can you show us your pspice diagram and error message?
  10. Ron Potashnik
    Dec 27, 2015
    15
    i took care of the capcitor eror. in the Amp3130 it showing me in the green eror "WARNING(ORNET-1119): No PSpiceTemplate for U1, ignoring"
  11. Jony130
    Feb 17, 2009
    3,990
    1,115
    The problem is that you should use the model from Orcad\Capture\library\PSpice not from Orcad\Capture\library\
    Also Fix your connections at node where R12, R11 and R13 are connected. Also at R2 D5 C2 node.
  12. Ron Potashnik
    Dec 27, 2015
    15
    so i copy the 3130 to pspice libary and it didnt change nothing )=
    what is the problem with the component you wrote?
  13. Jony130
    Feb 17, 2009
    3,990
    1,115
    LOL, try use a different type of a opamp , for example TL071.
  14. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Also the collector of Q1 is on the wrong side of R2 (2k2).
    Bertus
  15. Ron Potashnik
    Dec 27, 2015
    15
    so i tried the Tl071 and he is writing me the same error.
  16. Ron Potashnik
    Dec 27, 2015
    15
  17. Jony130
    Feb 17, 2009
    3,990
    1,115
    Well in simple word?
    For this circuit
    http://forum.allaboutcircuits.com/attachments/simulation-2-jpg.97359/
    Q3 , Q4 and 4.3kΩ - a shunt voltage regulators to power the op amp (CA3130).
    Q1,Q2,Q5 together with 2.2kΩ , 62kΩ, 1kΩ forms a reference voltage for a error amplifier (CA3130).
    And this capacitor is a compensation capacitor to prevent oscillation.
