help me solved qn 2 and 3!!!!
When you do, be sure to correct the "hint". I find "hints" with errors are pretty poor hints.I've grown so "fond" of this question I think I'll post it myself.
We are not mind readers. Show us what you have done so far so that we can see where you are going astray.I still can't get the equation that we have to prove...
Cos the qn is a bit different from the others. The Vout=Vr, we can't get the equation for Vc.We are not mind readers. Show us what you have done so far so that we can see where you are going astray.
It sure looks like the same question. How is it different?Cos the qn is a bit different from the others.
Why not? And why do you think that Vout=Vr, given the discussion on this point that has taken place in the other threads?The Vout=Vr, we can't get the equation for Vc.
I solved qn2 alr. Can help me on q3? I don't understand what is transient state and steady-state voltages..It sure looks like the same question. How is it different?
Are we to conclude that your position is that you should be expected to show any effort or any work and we are to just solve the problem for you and give you the solution all ready to copy and turn in as your own work?
Well, that's not what this forum is about. So I (and I suspect many others) have no interest in helping you until you show some indication that you have made a good faith effort to work the problem yourself.
so transient state voltages fade with the passing of time, because its a undesire voltage?Anything that is transient fades with the passing of time - like human physical beauty.
Things in steady-state continue on unchanged from the past to the present and into the future in a systematic / predictable manner - like ....????
Which of the voltages fade with the passing of time - why?
Which voltages continue on with the passing of time in a unchanging systematic / predictable manner - why?
It has nothing to do with what's desireable and what's not. When you ring a bell, the desired response is that it wiggle and make a pretty sound for a while and then go silent. That's a transient response. When you turn on an oscillator, the desired response is that it output a nice steady tone until it is turned off. That's a steady state response. it will do some funky things for a little bit when you first turn it on and finally settle down. The funky stuff is the transient response.so transient state voltages fade with the passing of time, because its a undesire voltage?
And steady-state voltage continue on with the passing of time in a unchanging systematic / predictable manner. but i dont know why...
oh okay. how about qn 4, i know is a high pass filter. but how do i explain.It has nothing to do with what's desireable and what's not. When you ring a bell, the desired response is that it wiggle and make a pretty sound for a while and then go silent. That's a transient response. When you turn on an oscillator, the desired response is that it output a nice steady tone until it is turned off. That's a steady state response. it will do some funky things for a little bit when you first turn it on and finally settle down. The funky stuff is the transient response.
If you drop a heavy box onto a diving board, it will bounce up and down for a while and eventually settle to a position that is lower than it would be if the diving board had been a rigid steel beam. The wiggling that dies out is the transient response and the final displaced position is the steady state response. Which of those, if either, is "desired" depends on what the point was in choosing to set a heavy box on a diving board. The system is what the system is and it doesn't give a damn about what is and what isn't "desired".
by Aaron Carman
by Aaron Carman
by Aaron Carman
by Jake Hertz
