help on plot parallel resonant converter using MATLAB
Discussion in 'Programmer's Corner' started by ljt, Oct 11, 2006.
  1. ljt
    Oct 11, 2006
    hi,
    i am now doing a thesis on analysis of parallel resonant converters. Anyone can help me on how to plot all the characteristic graph of parallel resonant converter by using MATLAB ??
    any ideas?
    thankz a lot....
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    It largely depends how your data is formatted and structured. As a starting point, type any of the following at the MATLAB command-line for further information and syntax:
    >> help plot
    >> help plot3
    >> help plotmatrix
    To plot multiple plots on a single graph, use the "hold" command.
    If you want more help you will need to be more descriptive of the formatting and structure of your data.
    Dave
  3. sci-3d
    Aug 22, 2006
    51
    There several plot routines depending on the kind of the data.
    Could you please specify you work. The people in this forum glad to help you. :)
