Help on Isolated AC voltage measure
Discussion in 'General Electronics Chat' started by vikramgholap, Sep 10, 2009.
  1. vikramgholap
    Sep 10, 2009
    6
    Hi All,
    I will be grateful if anybody can help me out.
    I need to convert AC line voltage from 110V to 560VAC to equivalent low voltage in 5V range either AC or DC.
    The requirement is it should be isolated measurement and should not be transformer based.
    If anyone has come across Optical Isolation circuit please.
    Appreciate your help. Preferably Analog optocoupler.
    Vikram
  2. studiot
    Nov 9, 2007
    5,005
    515
    Very important to specify the current (or power) levels involved?
  3. vikramgholap
    Sep 10, 2009
    6
    I need to measure voltage across Line and neutral. the current would be very less. Eventually the 0-5V signal needs to be given to a microcontroller
  4. vikramgholap
    Sep 10, 2009
    6
    The current would be very less.Eventually, the converted 0 to 5 volt signal needs to be given to a Microcontroller ADC.
  5. studiot
    Nov 9, 2007
    5,005
    515
    I would go for a resistive divider, about 100:1, across the power lines.
    100M in series with 1M would achieve this.
    You would take the output across the 1M at low voltage, rectify, amplify and schmidt it. The Schmidt output could then drive an opto isolator or be capacitively isolated.
    The divider should be made with say 4x25M resistors so 4 would have to fail short before subsequent circuitry was exposed to high voltage. Of course the 100M should be connected to the high side. The 1M could be trimmed for exact divider ratio if required.
    Remember if you are working at mains voltage to take proper precautions and seek professional help if you are unsure.
  6. vikramgholap
    Sep 10, 2009
    6
    Hi Studiot,
    I got your point but, after optocoupler/schmitt, we will get only High/Low. I will not get the voltage equivalent there. I also gone through Analog isolator datasheet. In that, we will need additional Opamps and probably an isolated power supply for the opamps placed at the input side.
    Is there any simple idea you know. The circuit is cost sensitive and Analog optocoupler would be an expensive business.
    Thanks for your kind reply. I would choose fail-to-open resistors
    Vikram
  7. studiot
    Nov 9, 2007
    5,005
    515
    OK so you don't need a schmidt for analog. But you will still need some signal conditioning to buffer and to get the output to appropriate level for measurement.
    In theory the opto isolator is not necessary, but it is still a wise precaution.
    You can get these with built in signal conditioning amps
    eg
    http://www.netvoxuk.com/opto-isolators.html
    Look for linear opto isolaters
  8. vikramgholap
    Sep 10, 2009
    6
    The link provided looks Ok. I shall check out for price with them
    Thanks for quick response
  9. someonesdad
    Jul 7, 2009
    1,585
    141
    If you use a resistive divider, make sure the resistors have the proper voltage ratings.
  10. studiot
    Nov 9, 2007
    5,005
    515
    Fair point, but I already said that and there is much more than just the correct voltage ratings.
    But hands are always thrown up in horror when someone suggests connecting a resistor or resistors across the mains, forgetting completely that all devices using the mains do just this. You just need to provide properly spaced and enclosed connections.
  11. fabius
    Oct 13, 2009
    Why resistive divider?
    You have to measure an AC voltage, consider using a capacitive divider.
    To attenuate for example 100:1, you need a small capacitor connected to the mains, and a capacitor 100 times larger at the low side, for example 1nF/100nF.
    After all you need voltage, not power. And capacitive divider do not waste power and do not heat (almost).
    There is plenty of safety capacitors designed and approved (so called Y type) to be connected between a net leg and protective earth, they let a very small current flow at 50 Hz, that is considered safe by all agencies.
    So no other isolation is needed, if you use one of these capacitor (for the large one there is no issue) touching the low side is as safe as touching the metal frame of a washing machine.
