Hello everyone
I need some hints or advices with my project......
The lecture gave me an electronic project but i don't have much knowledge in electronics so i'm really need some help or advices.
the project is to desing a delay module will produce a positive going pulse having an on-time of 50 msec duration and an off-time of a duration that can be switched between 16 secs, 8 secs, 4 secs and 2 secs.
the duration is to be selected by a momentary push button. One push press will give a 16 sec delay, two presses will give an 8 sec delay and so on.
the ouput will be a enhancement mode MOSFET - a MTP3055E device.
and i'm only allowed to use the following ICs
4011 - Quad 2 input NAND gate
4017 - 5 stage johnson counter with decoded active high outputs
4020 - 14 stage binary counter
4093 - Quad 2 input Schmitt trigger.
after reading the datasheets, and i think i can to use the 4020 for the delay, 4093 for the positive pulse, but whats the difference between 4011 and 4093, and what does 4017 do?
Thanks in advance for any hints or advices......
