Help on a simple project
Discussion in 'The Projects Forum' started by ravapps, Sep 1, 2013.
  1. ravapps
    Sep 1, 2013
    I need help on one of my friend's project in his studies. Project is : Two 12 volt DC inputs named A and B given, if A input goes off then a buzzer and small LED is switched on and if A input comes back the buzzer and small LED is switched off. Please help with diagram so that I can tell perfectly. I am beginner in electronics
  2. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    Yes, it is called a N.C. (Normally Closed) Switch!
    What is input B doing all this time?
    Max.
  3. WBahn
    Mar 31, 2012
    18,093
    4,920
    So your friend wants you to do his homework for him and, in turn, you want us to do it for you.
    Classic.
    Would it be possible for the two of you to come up with at least an attempt as a solution that we can discuss?
    Metalmann likes this.
