HELP NooB Here: Select one compatible charger for ebike: 6 options below.
Discussion in 'The Projects Forum' started by Greg D, Nov 22, 2015.
  1. Greg D
    Nov 22, 2015
    6
    (Pick 1) Ebike Charger stolen and have six possible replacements but can not understand the ins n outs and all than techy stuff.
    Can you help me select one of the bellow charger stats that I should purchase for this Ebike Charger that was stolen.
    DETAILS BELOW OF STOLEN CHARGER THJAT CAME WITH E-BIKE:
    LI_ION BATTERY CHARGER
    MODEL: HP8204L3
    INPUT: 115/230/VAC
    60/50Hz 2.5/1.5A
    OUTPUT: 36VDC/2A
    OR
    1 -New In Box HIGH POWER Lead-Acid Battery Charger
    Model: HP8204B.
    Input: 115/230VAC, 60/50Hz, 3/1.5A
    Output:24VDC/4A
    OR
    nput Volt 100-240V
    Output Volt 58.8V/14S (Li-ion cells 4.2v charge)
    Charging current 3A
    N.Weight : 1.139kg
    Dimension(LxWxH) 19.5X9X5cm
    OR
    Item name: Electric Bike 48V 2.5A Lithium Battery Charger E-bike Scooter For Lifepo4 Li-ion Battery
    · Input Voltage : 220V ( For Canada and USA country we will ship 110-220V Input Voltage)
    · Output Voltage: 54.6V ( If need different output voltage, Please contact us, we can adjust on the charger. )
    · Output Current : 2.5A
    · Output Power : 136W
    OR
    48V/54.6V/2.5A Charger For 48V(13 cells) li-ion Battery Pack Scooter Ebike
    mpatible Battery Type(s):
    18650/CR123A
    Electric Bike 48V 2.5A 16ah 20ah Lithium Battery Charger E-bike Scooter Lifepo4
    OR
    42V charger microphone head XLR connector for 36V NCM Lithium Li-ion ebike ebicycle battery wheelchair battery
    42V Li-ion Battery Charger
    Input: AC100-240V 47-63Hz 1.8A Max.
    Output: 42V 1.8A---2.0A
    OR
    Electric Scooter DC36V 2A Power Charger Lifepo4 Li-ion Lithium Battery XLR3 E-BIKEElectric Bike
    Note: The charger is suitable for 43.8 Volt Lifepo4 Li-ion Battery(12 series battery), is supported input AC 90-220V .Please make sure the
    Suitable for 43.8 Volt Lifepo4 Li-ion Battery batteries(12 Series battery).
    Casing material: plastic
    Dimension(LxWxH):155mmx88mmx53mm
    Input length:60cm
    Output Length:62cm
    OR
    2A Charger For 36V Li-ion/Li-Po Battery in Plastic Case :
    Input Voltage: 100-240V 50/60Hz
    Output Voltage: 42V (for 10 series 36V Li-ion/Li-Po Battery use)
    Output Current: 2A
    Charging Mode: CC-CV
    THANK YOU SO MUCH. I NEED THIS TO GET TO WORK AND SUCH. HAVE A GREAT DAY AND BLESSINGS.
    -GREG D.
    Feel free to contact me:
    Havre a good one.
    gregdiamondemail@g---mail.co--m
  2. spinnaker
    Oct 29, 2009
    5,085
    1,181
    Real simple. You need to know the power requirements of your eBike What are they?
    If you have any warranty left on the bike then I am guessing it will not be covered unless you buy the manufacturer's charger.
    Greg D likes this.
  3. Dodgydave
    Jun 22, 2012
    5,155
    772
    As you said in your post..
    Li-on 36V 2A charger is what you need, so get one that fits that spec, with the input voltage for your country.
    Greg D likes this.
  4. Greg D
    Nov 22, 2015
    6
    UPDATED INFO: I read your replies and narrowed my work too this.
    BIKE:
    NC machined 350 watt motor, the Forza (BIKE) combines comfort with power, supplied by a 36 volt Lithium Ion battery,
    M otor: Brushless 36 Volt Servo motor peak 700 watt / continuous
    350 watt with planetary gears.
    C ontroller: Custom build self diagnostic system with overload
    protection at 20 amps and low voltage cut-off at 31.5
    Volt to protect both motor and battery system.
    Battery: State of the art - 36 Volt 10 Amp hour Lithium-Polymer
    Complete with battery management circuit (BMS)
    C harger: Automatic Smart charger, maximum charge time 5.5
    hours (2 Amp)
    MODEL: HP8204L3
    INPUT: 115/230/VAC
    60/50Hz 2.5/1.5A
    OUTPUT: 36VDC/2A
    Charger choice #1
    Output Current: 2A
    Charger choice #2
    Electric Scooter DC36V 2A Power Charger Lifepo4 Li-ion Lithium Battery XLR3 E-BIKE Electric Bike
    Input:AC 90- 240V, 50/60Hz
    Output:DC 36V(43.8V, suitable for 12Series Lifepo4 Li-ion battery
    Charger choice #3
    Description
    Charging time: 8~10hrs
  5. Greg D
    Nov 22, 2015
    6
    OK Thanks for the help. I think i'm getting closer. I put up my refined info
  6. Greg D
    Nov 22, 2015
    6
    I posted it below also:
    NC machined 350 watt motor, the Forza combines comfort with power, supplied by a 36 volt Lithium Ion battery,
    Speed: controlled by EZ Assist Factor speed dial, pedal activate
    preset dial controller
    hours (2 Amp)
    I'm trying to learn this new language.
  7. Greg D
    Nov 22, 2015
    6
    "Intelligent Charger Very Good Self-heat sinking Performance"
    Anyone Know what this means? It costs 2-3 times as much. Dunno if worth it or not
  8. spinnaker
    Oct 29, 2009
    5,085
    1,181
    Usually an intelligent charger means it won't over charge your battery. Plus there is a real science to charging batteries. Especially ones like liion. It is more complicated than just applying a voltage to charge.
    http://batteryuniversity.com/
  9. Greg D
    Nov 22, 2015
    6
    http://www.ebay.com/itm/2A-Charger-...y-in-Plastic-Case-Ebike-Charger-/171335088439
    2A Charger for 36V Li-ion/Li-Po Battery in Plastic Case Ebike Charger
    Looks like this will fit?
    I just found an E-bike store that sells a generic charger for double the one. Think there is any difference?
    Thanks for any and all help. If you have questions on expedition hiking, & beginner or advanced snowboarding, or cool mountain towns in the USA I may be able to help ya... I guess you guys really dig this electrical stuff. I'm just trying to make my broken things work.
  10. BReeves
    Member
    Nov 24, 2012
    412
    64
    Either charger would do the job, just a matter of deciding if the difference in price is worth waiting on the one shipped from China. I have had good luck with ordering direct from China, but have to be careful in knowing what you are buying and be willing to wait a couple weeks or more for it to get to you.
