help neeeded with solar powered battery charger
Discussion in 'The Projects Forum' started by Oss, Feb 19, 2009.
  1. Oss
    Feb 19, 2009
    In the firist i want to wish for all helpful tips and trics what i ind in here.
    i hat a problem witch an solar powered supply witch i use for charge an lead acid battery but i cant find an circuit to cut off the power when its done to avoid damage the battery (14.4V+). i tested a lot of probable solutions but none of them work corretly. if anone can help or give me a tip?:confused::confused:
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Hi Oss,
    Can you post the schematics that you have tried?
    Tip: use the "Go Advanced" button below the reply box, and use the "Manage Attachments" button. The .PNG format for graphics is preferred; as they are fairly compact and not "lossy" like .JPG. Image sizes must be less than 100k bytes.
  3. Oss
    Feb 19, 2009
    in the first schematic i had an tooo high voltage drop in output and ater that a tried a few variations of solve that problem with relay the resistor in the second battery is only for the internal resistance of the battery. in the second pic a solved the voltňage drop problem but in that case i cant made an reference voltage for the OP Amp beacuse i want to made it to cut off the power only when a voltage in battery reaches 14.2 V.
    P.S
    Ow and please exuse me from my terrible grammar...
      File size:
      31.5 KB
      20
      File size:
      20.4 KB
      18
