Help Needed.
Discussion in 'General Electronics Chat' started by caluctra, Nov 29, 2010.
  1. caluctra
    Oct 27, 2010
    11
    Hello all...
    I need help limiting a 15Vac to 250 mA max; for example
    I have read here on the forum, but most of what it is discussed regards DC current limiters.
    any help will be apreaicated.
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    What is the load? A resistor can limit AC or DC current.
  3. caluctra
    Oct 27, 2010
    11
    Thanks for the replay
    the load is a transducer
  4. Kermit2
    Feb 5, 2010
    3,847
    963
    as in a pressure transducer?
    that should have a resistor already in it and you simply supply 'excitation' voltage. The resistance will limit the current on its own, as long as you don't give it a voltage too far out of its specified range. Should be listed on the side of the unit as 24 volt or 28 volt or 5 volt or 10 volt etc etc etc.
  5. caluctra
    Oct 27, 2010
    11
    it is a linear variable displacement trasducer, it has internal resistors and a coil.
    on one of the test "in the manual" it asks for a given voltage at a given max current allow.
  6. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    A 15VAC supply and a 250mA fuse.
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
