Help needed !!
Discussion in 'Embedded Systems and Microcontrollers' started by olvine, Aug 2, 2014.
  1. olvine
    Mar 10, 2014
    99
    I have written a code in C for atmel 89C51. How can I get assembly code from this ? Is there any possible method to get the assembly code ?
    I have use keil uvision 3 to code and c51 compiler.
    In mikroC asm file was generated when we compile C code....I haven't use keil much...
  2. ErnieM
    Apr 24, 2011
    7,438
    1,626
    Did you try to RTFM?
    (Note I don't use that compiler but I was able to find this in a minute or two.)
    olvine likes this.
  3. olvine
    Mar 10, 2014
    99
    Thanks for your help ErnieM....I have also never used this compiler.
    I think I might have to write assembly code myself because this compiler generated assembly code generate some labels I cant understand.
  4. olvine
    Mar 10, 2014
    99
    ok Thanks. Lemme download that one
  5. shteii01
    Feb 19, 2010
    3,504
    512
    I think I owe you an apology. I think I looked in the wrong folder. The asm file I saw in one of my Keil uVision 4 folders was the one that I created, not one that Keil made.
  6. mitko89
    Member
    Sep 20, 2012
    123
    19
